dieselndixie
so i am prepping "gredda" to spray the interior with bedliner
i assume the opening on the upper right of the passenger side floor panel is some sort of air intake for the A/C - please explain..it had a housing, a flap, and what i assume was a vacuum or somethin to open it.
and how should i treat this when spraying? cover the hole obviously, but put it back on when done? even the plastic panel? same question with the lower doors, what do those vents do, and how to i handle spraying the lowers part of the doors.
hell, let me know what yall did about the rear speaker wires, seatbelt wires, rear lights wires, and transfer case selector light wire too after spraying
