Hp tbi fuel injectors and vrfpr
crazy427
Edison , NJ
I have a set of high perfomance TBI Venom fuel injectors, they flow 10 % more than stock 5.7 injectors.I was running these with vacuum refrence fuEl presure regulator on my truck.( regulator is adjustable ,has new rubber insert with the valve,has had the tube cut down so a external vacuum line can be hooked up , has a 15lbs spring inside becuase the stock vrfpr spring puts out 20 lbs which is to much and i have the cussion valve that goes inline from the vacuum source so that when vacuum is applied it isnt a instant drop or increase in fuel pressure, it smoothly moves up and down). These all worked great on my truck when i had my 5.7 with a mild cam ,perfomace intake and headers. But with my new 383 set-up i doesnt push out the right fuel flow, so i have upgraded to 80 lbs perhour injectors and a stock regulator set to 12 lbs. I paid 299 for the injectors and 100 for the vrfpr with accesories.
asking 250 for the set-up , Pm me with any questions and i will have some pics on monday.
Joe
Offers any one?These are a must for anyone who has more than a stock tbi engine.
Do you still have this set up? I would like to install this on a Caprice crate motor I just bought from GM. Its a roller cam throttle body motor.
Thanx Nick
