454Sub
5/8 ton status
Does anyone happen to have or even know factory 8.1 truck injector pulse width numbers? And the minimum width.
I'm using it to do a hodge podge of a 5.3 build. Right now it runs decent ish with the KPA injector table set to 29.9 across the board. But technically an 8.1 injector I believe pushes 35-38lbs at 58 psi. So knowing these numbers are obviously not correct and my VE table being strange has led me to believe that it's my injectors and their info that is not jiving with what I currently am running.
Anybody know of anyone who would happen to of opened a factory 8.1 03- truck and would have the injector data?
