has anyone used this cam or thought about using this cam. looks to be a huge tork monster.
I can recommend a better hydraulic roller cam for torque but it also depends on other factors of your engine.
Go with a Comp Cam, they have the latest technology as far as i'm concerned. They are the leader in cam technology these days. What heads are you running and what is your actual CR?
question being will the roller rockers fit under Edelbrock stock hight valve covers.Stock compression is "supposed" to be 9.3:1. If you actually checked it they are closer to 9:1 but the cam i listed will work good. I would not suggest using it though without having screw in rocker studs as it is .550/.547" lift and roller cams do use more spring pressure so you would need the proper valve springs and the stock studs wouldn't last long before they started pulling out of the head because of the higher spring pressure. Like i said, that cam also uses 1.6 ratio rockers and they would either need to be full roller rockers or long slot rockers because of the high lift.
also is this cam cumputer friendly
