bad larry
Afternoon, dose anyone have the diameter of a GM dana 60 hub say 3" out from the wms? I ordered some spacers and they are hubcentric wheelcentric but the wheelcentric part won't clear the wheel hub... My verner calipers are only 6" and the jaws are not long enough for the max OD of the hub, not the lock out but the wheel hub itself. From what I CAN measure it looks to be in the neighborhood of 4.47-4.50"? Should be the same as the 14bolt correct? I'm gunna take um to the shop and put um on the lathe but I need an exact measure so I can retain the hubcentric...
