Hub rings.
r3bartl
Registered Member
canada
Does anyone know of a company that makes hub rings for 3.5 inch warren lockers. To 107.5. Doesn't seem to be anything available for those sizes.
Are you talking about the o-rings for the knob bezel that seal to the bearing hub?
"To 107.5" < what is this?
No just hub rings to keep the wheels on center. 107.5mm OD and 3.5inch ID.
It's a Monday so I'm foggy but I cannot think of a Warn locking hub part that's for centering the wheels. Can you attach a pic?
It's a Monday so I'm foggy but I cannot think of a Warn locking part that's for centering the wheels. Can you attach a pic?
I should of left the warren part out of it. I just didn't know if there was something made specifically for it. Just a regular hub ring. They just don't seem to make it for 3.5 inch hubs.
Oh ok, I'm up to speed now. I've seen those for aftermarket wheels (most are lug centric instead of being hub centric like OE wheels). Maybe try the wheel manufacturer directly?
the rims do have tappers for the lugs and I've torqued em on and tried to get them center but it's still off. With the rings u know atleast it's dead on. But that's a good call. I'll message them as see if they got anything. If not it might be a machine shop job.
Give these guys a try. Couple members have used with good results
