Hummer Beadlock Question
TerryD
Mildly demented...
Covington, Va
Has anyone ever tried to put Hummer beadlocks on a K30 DRW? I know you have to have them re-centered to run on SRW hubs, but what about DRW? I've found a bunch of duallies and what I really want is a SRW truck. If this would work and not look too stupid, I may go that route if I can find a Dually I like. It would certainly open up my options. Thanks guys!
i've heard that way is indeed the way to go about it, my brother has hummer wheels on his burb, but he's got 2" adapters up front, never had a problem with em, the back is just fine, it only hits on the tierods on the front however..... and maybe the caliper... i dont remember, but for sure the tierods.
so if you have a srw now you are good, but you'll need the dually stuff up front, or spacers, or recentered wheels....
bolts on the front perfect with drw
then if rear is van width thay bolt on the rear.
if dana 70 wide drw axle swap on srw hubs/drums and bolt on. or 3" spacers and bolt on.
I run a DRW 60 and h1's, in the back just a regular 14 ff with 1.5" spacers. Its a little bit skinnier in the back but not too much. Search there are lots of threads on this. 38.5x15.5x16.5 tsls
