Hummer Rim ???'s and 14 bolt from 1 ton
reddog64
Federal Way, Washington
I am picking up a Dana 60 and 14 bolt out ogf a duelly 1 ton.
I want them in my 78 K5.
I know I can run hummer wheels, or swap the front hubs down to single wheel hubs (or turn them down if wanted...)
What about the rear 14 bolt...
Is it too wide? or will running the hummer rims work for it too...?
Will it mount up w/o moving spring perches?
Where can i get a set uf the hummer rims...
usa6x6 you can get the rims..and i'm next to positive you have to swap the hubs front and rear to run srw....
If it is indeed a wide 14 bolt then you can run H1 rims with out doing anything. If it is a C&C 14 bolt (narrow) you can put SRW hubs on it and it will be a SRW 14FF then you can run spacers and the stock H1 rims.
Chances are you actually have a Dana 70HD which you can also run H1s on. You can also swap on SRW hubs from a 14FF and not run any spacers at all on the rear.
As far as USA6X6 do a search and stay far far away from them. Nuthin but crooks:mad:
Dik
even for the cool flexy pvc inner beadlock ring thingy? i want to get some of those.
I would spend more money to buy from somewhere else.
Just do a search for USA6X6 and you will see what I mean.
Stazworks sells those inserts also but theres are a 1 piece HMPV or what ever that stuff is. USA6X6 has had an issue with their inserts breaking
Dik
