Hummer Rims on dually? Pics?
Bookshelf
Registered Member
Chicago Suburbs
I've searched a little, what has to be done to get hummer rims on a dually truck, making it a SRW? I don't want to use spacers either. If anyone had pics that would be great. Thanks
Dually front is a matter of bolting on the wheels.
Search for the forum for posts by "boz42". He also has pics in the Photo Gallery. :thumb:
Are you wanting to put them on a dually? or on a truck w/ dually axles?
If you have a dually, & it has a regular dually bed on it, w/ a d70hd rear end. they will bolt on w/ no mods. If you want the rear to be even width w/ the frt you will need to swap the rear from drw hubs to srw hubs. that will widen the rear to the same width as the frt. Here is a pick of mine w/ stock backspacing H-1's (they have a weld on rock ring). My axles are d60f drw & a 70hd w/ srw hubs. both axles would be from a chevy dually.
