nkgilbert
Registered Member
This thread is for the general discussion of the item Humpty Dumpty Wrangler Project. Please add to the discussion here.
Yeh, not sure, but will let you know...I do know the gears are different so we will have to swap them out to match. I think it's a 3.88 or 3.83, can't remember in the front and 4.10 or 4.30 in the rear.Good chance your front axle is from a Wagoneer. The Isuzu D44 is a popular swap because it has disc brakes and is a similar width with 6 lug wheels. I used to have one with the AMC model 20 rear. I was looking for the Isuzu D44 as a swap for the model 20, bit stronger and disc brakes. Never did find one and sold the truck eventually.
Yeh...looks like I have the same procedure coming up on this one...should be good to go once we get the origin of all the parts. I saw you coming right along on yours, looks good.Glad you started the build, looking forward to seeing it in person. I recognized the welding table as the one we used to set the gears on the k5s front d44
Thanks, give me heads up when you get ready to set the gearsYeh...looks like I have the same procedure coming up on this one...should be good to go once we get the origin of all the parts. I saw you coming right along on yours, looks good.
sorry to disappoint...would be pretty sweet though.I clicked on this link hoping to see one of these!
I imagine this will be neat anyway.
Martin
Thanks...wasn't sure if this was the place for that or not...will try there. Yeh we plan to put things back together this weekend...all the parts are in and everything is cleaned and ready to go. Have some concerns due to the lack of sacrificial bearings as they got sacrificed during the teardown...gonna throw it back together with the same shims and see what it looks like.If you dont get replies on the cylinder issues, repost the specific problem in the garage and more people will see it. You'll likely get all the input you need in a short period of time. Let me know when you're gonna set the gears. I want to head over for that
Forgot the add the URL for the differential place...www.differentials.comRear Axle assembly didn't go as planned. We were able to assemble the pinion and carrier and test the pattern with the old crush sleeve to see if the shims were good. Pattern came out fairly good, might be a little towards the toe of the ring gear in my opinion but we're gonna go with it. So we moved forward with the seal and new crush sleeve, nut, etc. (final assembly, right...wrong). We ran into a problem getting the pinion bearings to suck up together on the pinion. There was some discussion as to whether it was the crush sleeve or the bearing that was causing the issue, keep in mind we already had 200 ft/lbs of torque on it. After ruining the seal and examining what the issues was, turns out the crush sleeve wasn't crushing...put it in the press to start it then had to dig out the 3 foot pipe wrench and 5 ft cheater bar on the 3/4 drive ratchet. Probably took 600 ft/lbs to crush the sleeve and get about 10 in/lbs of preload on the pinion. Got another seal and a solid spacer coming for the back...gonna try that route to keep from replacing the crush sleeve each time it comes apart...shout out to the guys at West Coast Differentials. Guys were amazing when it came to identifying the parts for the rear end and getting them shipped out in a timely fashion...received them in a few days. Test pattern pictures below...any feedback / opinions are welcome.View attachment 375672View attachment 375673
I read on some other forums that the spacer is better and more durable for more aggressive 4x4 applications, both ways are acceptable and can be interchanged (i believe that is the case, when I asked the guy at west coast he didn't act like only certain axle assemblies would take a solid spacer). We didn't necessarily need the spacer for those purposes but we wanted to try the swap to see if it was something that could be done if at some point I really needed to do the conversion in a higher HP application, either on a street application or off-road. Also, the guys at West Coast had the parts in stock so and now I don't have to replace the crush sleeve if I'm just changing the seal...honestly I'm not seeing the upside to using the crush sleeve other than being lazy.Where did you get the spacer idea? Seems like it would be fine to do it that way since the front dana 44s are done the same
