Stomis
Professional Amateur
Well my ford towers and long travel shocks came today. I cant wait to put them in so I dont have to feel every single crack in the road...
Do the Ford towers and longer shocks make that much difference on the street? How much longer of a shock do you have to run with the Ford towers? And one last question, how difficult is it to install the Ford towers?
What does a welder have to do with anything? The ford towers bolt on.I dont' think they make any difference on the street over the stock mounts and a quality shock. Off road is where they help the stock shock can limit both compression and extension, depending on how your suspension is setup.
As to how easy are they to install? Do you have a welder? If so very easy. I have never bolted them on but I imagine it can be done with a drill and a couple of bolts.
I havent done them yet but I plan to match the eye to eye in the front to the rear. I bought shocks for a 4" lift in the rear and plan to run them front and back.
I dont know about ride quality on the street. As said i dont think it makes a difference its all about when you flex. It will make a difference going from shocks with 10% their stock rebound to brand new ones though![]()
Still wondering if these towers are just simply bolt ons or if there is any mods involved.
Oh, so that's what you were referring to when you said "that way I won't feel every crack in the road".
Of course worn shocks do not make the ride harsher, they actually make it softer. You just loose damping and control, and even keep bouncing multiple times after hitting a bump. Whenever I see people get jarred in a vehicle, they say something about the shocks when in in reality it has more to do with the spring rate.
I agree with that statement, for the most part.
) - actually they're primary purpose is to damp out low frequency vibration (bouncing) in the springs. New shock abosrbers will typically ride more harshly than worn out ones, but they will eliminate the double/triple bounce over bumps.
