Wanted HVAC parts
Rugby_7
Glenwood Springs, CO
Decided to condense my wanted threads. Looking for a few things for my 1975 blazer with factory A/C
Passenger side a/c vacuum kick panel. Color doesn't matter. (see below for what I have)
Center a/c vent.
a/c heater control. Mine has a broken fan switch but wouldn't mind a whole unit in good condition. Mine needs some gluing.
Might have, please clarify which part(s) you need
LH A/C kick panel
RH kick panel
if either of above, color?, short or tall?
steel RH flapper door
vacuum diaphragm assy
plastic diaphragm cover, color?
LH A/C kick panel
RH kick panel
If I can get the whole assembly it would be awesome. Mine is pretty beat up and missing the cover. It's the short style just passenger side. I'm going with a black interior but can dye it.
Center a/c vent.
View attachment 220830 View attachment 220831 View attachment 220832
I should have all of this.
I'll be home tomorrow night and I will confirm.
I have some parts here, but not correct for a '74. All of my stuff is from an '86, and some newer...
I think the HVAC controls have to be pretty specific. As long as everything looks the same it should work though. The center vent I think crosses over multiple years. I've seen a couple versions of the kick panel. Would like to stick with the shorter style. Mines missing the round cover though and the gaskets are beat.
Man I am sorry! I was going to look at the parts that I stashed at work, and crap went downhill, then I forgot again....
So I finally got some parts rounded up. I don't know if these are much better than what you have. I know that this kick panel came out of a '78. The center vent that I have works well, but the chrome is done. I wiped it off some, I don't know right now if I have a better one to sell. I didn't test the vacuum actuator. I would sell all of the parts for $20 plus shipping and fees. But I would guess maybe $15-20 for shipping. That may be more than you are thinking???
Sorry for the delay..
Don't know how the pictures got flipped upside-down....
How are the gaskets on the door? Do you happen to have the heater a/c control? The center vent looks to be about the same as the rest of my vents, do you have the housing for it too? Thank you for looking for these things for me!
The oldest control panel that I have is from the '78 and it isn't correct for yours.
The seal on the vent door is complete, but cracked.
Yes, I have the housing for the center vent. (The part which holds it to the back of the dash bezel) That's worth a couple million, right? Hahaha!
So I don't know if you would be better to buy a new venture door vs. this used one.
But the one from LMC is pricey....
Sorry that I don't have a silver bullet solution for you!
