Hvac vacuum line
pparker
Texas
Not sure where this goes has been hangin out looks broke.
One end goes to heater door other end goes back to temp control switches.
That goes through the firewall, probably behind the duct work. You should see the other end of the line in the engine bay, slightly passenger side of the engine.
I will look, i redid the engine stuff cut out smog and capped but left everything else, made sure not to touch anything went through firewall.
Its a tiny little line.i guess that rubber boot is what made it go through firewall and sealed
I wonder what it went to after firewall, since i removed other stuff all new lines it might not be there depending what it tied into. Wasnt on vacuum diagram for sure
What year? I think it should tee to a line that goes to the vacuum reservoir, and the other end into a check valve and then into manifold vacuum on the carb or intake.
That line goes into the manifold vacuum (right port on carb) in my '82.
1986 i got line does that already ill put in picts
So the line that tees off like you said goes thru firewall and to temp control area
Third picture shows the line in talkin about that comes from temp controls to the heater flapper on far pass side and not sure where this broke off one goes
I only capped off smog, so unless it somehow teed into a smog line, i dont know how im missing
The wipers and the metal grill and plastic grill underneath all have to come off to access it.
Now i gotta dig out a toothpick someone broke off in it, great. Lol
