hydraulic Assist
pomai
Oahu, Hawaii
I would like to install Hydraulic Assist into my 88 K-5 Blazer, Dana 60/14 blt ff.
I have your Dedenbear Knuckles, Cross Over/High Steer Steering and Arms. I also have the PSC 80-87 GM Truck Crossover Steering, which is ported for Hydraulic Assist, Item Code #041MR
I'm in the middle of installing a Hydro boost brake system from a 86 M1031 truck.
I can't afford to purchase the complete Hydraulic Assist System at this time, but being that I was going to swap in the pump from the 86 M1031 for the Hydro boost system, I thought that maybe a good place to start, would be the PSC high output power steering pump with reservoir can and filtered remote reservoir. This way I can get the pump installed and find a good place for the remote reservoir.
What do you think of my plan, Would I be able to run the pump and reservoir without the rest of the assist system for know?
Also, could you give me the shipping cost?
Thank you,
Ed Marshall
You can absolutely use the pump and reservoir now and then just add the cylinder later when you're ready. We responded to your email with a shipping quote.
