Stomis
Professional Amateur
So I got my truck all buttoned up and I think I made a mistake here. I put an internal throwout NV3500 in it using the stock 3/4in clutch master. The master from the application the trans comes from is also 3/4. The only thing I changed hydraulically is that I went from the quick disconnect line to a -4 AN line. The -4 line is 1/4 and Im fairly certain the factory line is 3/16ths.
Well the problem Im having is the slave cylinder does not want to fully disengage the clutch when the clutch pedal is maxed at the bottom. Will the change in hose size in turn reduce the travel the master puts on the slave cylinder?
Ive never really played with mix match hydraulic stuff. I had just thought the line would hold extra volume but the displacement was the displacement...
Help?
Help?
