Hydraulic Clutch Pedal Set - Vacuum to Hydraulic Booster?
nitro_rat
Lufkin, Texas
I already have an automatic hydroboost pedal set.
If I get a hydraulic clutch pedal set for vacuum boost, can I swap the hydro stuff from my automatic pedal to it?
Or am I stuck finding a hydro clutch/hydro brake pedal set?
Yes, it will swap. This is exactly what I did. Check out my CUCV thread (start here if you just want the pedal portion)...
You have at least 3 options for making the pedals work (as detailed toward the end of the thread).
