Hydraulic Clutch...yay or nay?
Randy92782
1 ton status
Arcadia, MO
ok so i'm really thinkin of going with a hydraulic clutch. i got a 85 K5. friend did it on his truck and it's nice. just wonderin the pros and cons of doing this upgrade. what's problematic about it and would it be worth the money if i still drive it like i stole it. lol it'd mainly be used for a daily driver but it'd see it's fair share of offroad too. mud, hills, trails, etc.. thanks for any info
first time your Z-Bar linkage binds up, you will realize the better feel of the mechanical clutch, isn't worth it. I'd convert anything I owned from now on.
thanks man that did help. really like hydro clutchs. but don't wanna have to do too much work. oh well still gonna do it.
hay also my pedel assembley was from a 1/2 ton with vac brakes. all going in to a 1 ton with hydro. the best part for me was my pedel assy i scored had a second hole above the first so i could move the pin up to match the hydro rod position.
i actualy removed the pin from my old auto setup and welded it in to the second hole. so now i have a 2 pin pedel for vac or hydro if i ever part the truck out.
I have a hydro bellhousing, clutch pedal, slave cylinder, tin cover for bellhousing, the line and resivoir, and clutch fork (so everything but the master cylinder) for sale. I havent posted it up yet but let me know if your interested... My email is [email protected]
well i just might be. it might be a while so if you sell it good luck to the guy that gets it. but idk may be sooner than expected...?
