Just wanted to check my thinking with some of the experts around here. Only done this once, All the diesel Engines that i built back in the day had non-hydro lifters and required actual valve lash adjusting.
So I Spin the pushrods between my fingers while I also tighten the Rocker nut. Once i can bairly spin the pushrod I then turn the nut 1/2 - 3/4 turn. Dont worry I didnt forget #1 TDC, etc...etc...Just curious about the actual adjusting.
Sound correct?
Sound correct?
