hydraulic oil ?
sweetk30
Back to play nice .
in the back of your brain
hydraulic oil viscosity ?
power unit calls for aw-32 only . its to thick for flow rate needed at temp range its running at .
will it hurt to run iso-15 ultra low temp fluid ?
the power unit says this DO NOT use dex / atf / tractor hydro / jack hydro fluids . only aw-32 oil in this unit.
looks like the aw-32 is a 10w oil thickness
and the iso-15 low temp pour point stuff is a 5w or just a hair under .
talked to the local rep I got the low temp from and he said no problems with my intended use . and the companys didn't say no go with it for the products involved .
so game on I guess when I get a few extra seconds. :doah:to much work no time to play .
