I searched found nothing that relates.
My question is I have a box that the end is tapped well it has a new end on it, and the top where the slector shaft bolts in at is tapped. Which fitting make the ram go left and which one makes it go right.
Since were on the same subject where on the ram do the lines go as in relation to turning left or right
If you had the tie rod mounted on the hi-steer arms behind the axle, I think they would be reversed.
