I have a Dana 60, Detroit locked, under the front of my truck and I'm still running stock steering. This isn't working very well, when wheeling, I can barely steer, especially when I need to. The pump really whines a lot too. I need to go hydro-assist. My steering box is already tapped and ported by WTO, and I have a Rockstomper tie rod already installed.
A while back, Kid Jethro had a good post 'hydro-assist for under $100', which I have read and re-read. The hydraulic cylinder he used was from Surplus Center, which I had also stumbled across previously. The cylinder he used had SAE-4 ports, which are roughly equivalent to 1/4". That cylinder is also no longer in stock. Surplus Center has another similar cylinder in stock, but it is equipped with SAE -6 ports, which are roughly equal to 3/8" ports.
Would using the larger line size affect my steering ability/feel? Would it be slower/faster or easier/harder to steer? I'm new to the hydraulic stuff...maybe I would be better off buying a complete set-up, than piecing it together...
Thanks, Mike
Thanks, Mike
