1-tonmudder
The hydro assist on my M-1009 is loosin a lot of fluid and it seems to be comin out of the vent hole in the end of the cap.I used a piece of rad hose with a cut off res neck in the end of it.The problem only seems to show up after heavy steering/brake usage(I have hydroboost also).On the last trip I had to put 2 quarts in it,in one day.Everything is tight and I feel like it is bein pushed out when the cyl cycles back.It also seem's to get air in it when the front of the truck is on steep inclines.
So anybody have any suggestions on how to fix this?? Do I need to change to a remote res,and if so what kind are you guy's running???I have a cooler for the ps fluid that is on the rad support,but I am consdering changing to one with a fan.
Will a different rem res mounted on the rad support above the pump help??
