dustin.dstroya.montoya
I am looking for ideas on ps coolers and getting more fluid capacity, lets see some what you did.
Do you have problems with the hose leaking or what?
Do you think that the capacity in the cooler is enough or should I install a res also?
Thanks Chris, the doubler is the shizz
I ran a chevy remote res from a truck with hydro boost above the pump two coolers. One i purchase from PSC that can handle the system on it's own and the stock cooler just for extra support and it helped save buying hose. I also put in a remote trans filter that hold a TON more fluid and probably increased my fluid capacity the most.
What i did was mount the res above the pump(first pic) in between my york and alt. with heat sheilds then i ran to the box and from the box to the filter(can post pic later of that) I mounted the filter passanger side lowest point on the frame cross-member so when i change it or flush it the fluid won't get everywhere.(but still kept it safe) Then to the aftermarket cooler also mounted passanger side(pic two). Then to the stock cooler which i bent (pic three) so that the inlet was next to the out of the aftermarket cooler. you can see the inlet in the second pic in the bottem left corner. Then back to the pump. I also wasn't stingy on the hose length since it doesn't hurt and adds cap..
So far everything is working perfect and is neat, clean and out of the way, like it should be.
I want to set mine up like yours.
