F-ingrob
Wheres the mud
can a stock steering box on a 87 blazer be modified for use with hydro assist steering
Yes.
All it takes is some dissasembly and drilling and tapping two holes (best way)
Or buying a endcap that has a npt bung like diy4x sells and removing and drilling/tapping the top cap were the sector shaft adjuster nut is
I am not convinced the dissasembly method is the best way. I used diy4x's end cap and drilled and tapped the top cap of my box, and it works just as fantastic as guys who run a PSC box that is drilled and tapped the sides. To me, it just causes more work to dissasemble and make sure you don't leave any metal shavings in there. But to each there own I guess
