Can you please post pictures of your hydro assist setup thanks .
I have high steer crossover I’ve seen a lot of pictures With the rod pointed towards driver side wondering if it matters?The ram body should be mounted to the axle so the hoses don't slide side to side when steering. As far as the body of the ram being in the center of the axle, it just makes sense to keep the hoses routed away from the springs and tires.
I got under there today I’m to see how it could work out best way to mount on my rig seems to be rod end towards pass and closed end towards driver . Similar to this.Usually you mount the ram close to the diff and the shaft end goes to the longer axle side (driver if using GM or Dodge axle, passenger if using Ford) trying to aim it the other way can make for clearance issues.
