Alright well Im swapping my old mechanical linkage to hydro and Im running into some problems. Heres the back round, its a 85 m1008 that started out as a auto. I swapped in the 465/205 with a mech linkage. I used a clutch/brake pedals from a 79, that bolted right in/on to my hydro-boost setup. Now Im trying to put just a hydro pedal onto my pedal in there now but finding that its too far over to the right causing the rod to not be straight. I have access to a 86 hydro pedal setup, but its way different, im guessing cause its non hydro-boost? So my question is it possible to put a hydro pedal onto a older mechanical pedal setup, or do I need a hydro pedal setup off of a 1 ton or something else that has hydro boost?
