I`m swapping a hydro boost brake system into my 77k10 out of a 81 k20.
Will the master cylinder from the vacuum assisted 77 work on the 81 hydro boost system?
They look the same, I thought if I just use the master that I got hooked up already it could save me from bleeding the brakes.
The 77 was a two wheel drive converted to 4x4 with 1/2 ton axles, converted to 3/4 ton axles now. The master that I`m using seems to work good.
..after I went and bought the adapters and put the lines in the right ports,all was fine again...
