hydro boost pushrod baffle
v6toy4x
Registered Member
Union City CA
In trying to reinvent the wheel I opted for the newer hydro boost setup from an 02 silverado 2500HD. These are factory setup for the large 4 wheel discs so thought it would be a good candidate. The problem however is the MC has a larger bore than the normal hydro units so the standard baffle spring for the pushrod is too small in diameter as well as the pushrod appears to be too long. Does anyone have the part numbers for these parts?
02 silverado 2500HD
--hydroboost pushrod
--main pushrod spring
--pushrod baffle
--pushrod baffle spring
Duane
