Hydro boost Unit
pomai
Oahu, Hawaii
Where can I get a good quality Hydro boost unit that will bolt right into place of the 2, I picked up in 2 years from Amazon, Cardone 52-7307 Remanufactured Hydraulic Power Brake Boosters. Found it leaking inside the cab once again.
My system came from a 1986 K30 M1031 truck.
Thank you,
Ed
I had mine rebuilt after dealing with remans from the parts store in my M1008. I used a place in San Jose that gas done for me in the past. https://pwrbrake.com/ I think it was 200 rebuilt and shipped.
looks good, what is the extra mounting plate for ? Like the -an fittings.
being able to change the brake pedal rod with messing with plunger is a nice feature too.
Looks like I may have to remove the oem mounting plate from the booster and install it on the new one, Ill check to see how the brake pedal rod aligns with the brake pedal using the Vanco bracket and how it matches with the fire wall.
20240719_075911_resized_1.jpg20240719_075440_resized.jpg20240719_075447_resized.jpg20240719_075403_resized.jpg20240719_075310_resized.jpg
Thanks for the info....I was just getting ready to ask about mine. I'm close enough to drive to Downey and ask them exactly what I need.
