The "right" way is to use the flex line,but you probably could get away with brake tubing at least temporarily by winding some "spring" coils into it like the master cylinder lines have in them..I dont recall seeing any hard lines breaking off at the master cylinder on anything yet,unless the cab is bouncing off the frame due to rotted mounts or missing bolts,etc.............................................................................................One day I had a front rubber brake hose fail while plowing,and I used steel brake line as a temporary fix till I could get a new hose...I drove the truck to several plow jobs up to 10 miles away with that in place,I wound it around a big pipe to put some pigtail coils in it and routed it away from the spring and any other things it could get caught on...I did this in late January and never got around to fixing it right till the end of march!...I figured the line would flex a few times and snap right off,but I guess since my front axle didn't move up and down much with the plow on it (it touches the bump stops with the plow raised!),I guess it didn't move enough to snap the tubing off...I wouldn't reccomend this for daily driving,but in an emergency,I've done worse things to get home without paying for a tow when home aint that far away...
