ntaj*ep
OKAY!!!! I finally had it with replacing automatics and am doing a manual swap into my 75. SO, I have all factory parts except for the clutch master and pedal but can not get the clutch to release.
GM Hydro bellhousing
GM slave cyl
Hydro clutch fork
Hydro clutch kit with throwout bearing
Wilwood clutch pedal and compact .750 master attached with braided line
I have bled this off the truck and on the truck, I have no air in the system. I am getting alot of travel at the clutch fork on the transmission. But it will not release the clutch enough to get it into gear.
I tried to extend the slave rod as there seems to be alot of play before the throwout bearing hits the diaphram, it firmed up the pedal but still did not release the clutch. Also the fork looks like it is getting super close to maxing out in the bellhousing.
WTF am I doing wrong?
I have ordered 2 other Wilwood masters one is the same bore .750 but has a longer stroke the other is an identical stroke but has a .70 bore.... I am at a loss here and need the CK5 knowladge base.. Someone here has to have attempted this swap before and has some insight for me.. HELP I Have an event on mothers day weekend and am trying to make it happen!!!!
GM slave cyl
Hydro clutch fork
