Hydro clutch travel
Mark1968
SW Ohio
Just finished putting a hydro setup in my 79. New slave cylinder and line. Bled it out a good bit. It seems to engage way too close to the floor. If I push in the clutch, put it in gear it engages almost as soon as I let the pedal up off the floor. I'm guessing I need to bleed it out some more?
I've bled mine a couple times in the last few months (new MC and later a new slave) I've found the best way to bleed it is just how the service manual says to. Its pretty much just like bleeding the brakes. I had my kid work the pedal last time.
