Hydro Line Orientation
silveradoreb
Boone,NC
Well I am planning my hydro assist. Got lines made today, and tried searching, I am wondering which line goes where. I remember someone said at one point, but couldnt find it. I have the front cap from JKW and the top cap tapped. I belive the fixed end of the ram goes to the front cap on the box, but I wanna be sure......thanks for the help.
Best thing to do is to leave one end of the ram unattached from the tierod & hook the lines up either way & test the throw of the ram. Then swap the lines if it is wrong. If you put the lines on backwards w/ the ram instlled it will most likely blow the end cap off of the steering box.
Yea, this is what I was gunna do, but I had my lines crimped a certain way, so The lines are different and only go one way.
I made both of mine the same, so it wouldn't matter. I have a WTO box & my ports are close together. Also if a spare was needed, I would only need one.
