Hydro Ram, would this work?
Mudbug1979
Monroe,North Carolina
The joints are probably really cheap, they're out of stock and the ports would point directly into the axle or tie rod.
It may be possible to grind the weld out, turn the end and weld it back up like is mentioned in the thread you referenced but I'm not sure how that particular ram is put together.
