I’m swapping in an sm465 in my k5 i have all the linkage for the clutch. Before buying I looked for a hydraulic setup but couldn’t find one so I pulled the trigger on mine. Anyway I have the chance to buy a hydro bellhousing and slave/master for $150. Question is is the hydraulic clutch that much better and will I need anything else, does the hole in the clutch pedal line up the same for the master cylinder or will I need a new clutch pedal? Thanks
