Hydroboost Brake Lines
NEK5
3/4 ton status
Ipswich MA
Since the cab I got (originally a 1 ton dump) had hydroboost, I decided just to stick with it. But, part of my project is replacing everything...
I`m just about ready to order my new lines, so I wanted to double check, before I went and ordered the wrong ones.
LMC has a stainless pre bent kit, listed for the blazer, but its obviously for vaccum brakes.
My question is, does hydroboost and regular vac brakes use the same lines?
Yes, same lines. I swapped from vacuum to hydro and did not change any hard lines. The only difference is the hyd. hose used to connect the hydro unit to the PS pump and steering box.
