Kain
3/4 ton status
any of you guys/ gals running hydroboost brake conversion?
if so were did you get the kit at?
Its the easiest and best swap ever. Pulled the hydrobooster w/ master cylinder off a diesel truck for 26 bucks at the pick-a-part. Stopped by autozone on the way home and got both new pressure hoses for another 30 bucks, about 4 feet of hose for the return lines, a brass barbed "T", a magnetic power steering filter and some hose clamps. The T is only needed if your power steering pump only has one return line.
The hydrobooster bolted right up. I think I had to hammer off 2 studs from the hydroboost mounting plate because the firewall already had studs. Didnt even have to change the pedal for mine, the shaft was the correct diameter for the rod.
It was a total of 80 bucks because I wanted all new hoses and added a filter as well. Took less than an hour to do, really easy and it has a nice solid linear brake pedal feel that works as fast as you can press it. I can lock up all four 37" tires at any time if I wanted to.
i did even googled it tons of right ups but i dont want junkyard brakes.use search button
i di even googled it tons of right ups but i dont want junkyard brakes.
are you finally installing thet 7ft long drivetrain with 8 shifters?
