Hydroboost conversion
shock88
Electric Pole Dancer
CT
so i put a ‘99 C3500HD master on for my rear disc…and due to clearance issues with my valve covers (LS swap) i’m thinking of converting the truck to hydroboost….will i run into any master cylinder fitment/stroke issues when doing this?
Shouldn't you will need to check rod depth in master, but should bolt up
Might find that answer in the hydroboost tech thread:
There are a few different mounting patterns for GM truck master cylinders. They don't just all swap back and forth. Check your particular master for fitment with your particular booster.
I put in a hydroboost from a 2005 sierra in mine I had to drill out the mounting plate to accommodate the studs one the fire wall.
hey thanks for the insight guys! sorry for the delay, i never got an email saying people responded ‍♂️ but i definitely appreciate it, pics helped a ton, as long as i have a good starting point i think i can do some math and figure out these master cylinder bore/stroke numbers out
