my 1985 K30 with a 454 engine, and Hydroboost braking system is having a problem. The Hydroboost is getting blazing hot when the engine is running. I have never run into this type of problem befeore with Hydroboost.
When I remove the steeering pump belt from the power steering, and start the engine, the Hydroboost does not heat up, thus this tells me the problem is in the Hydroboost system.
The heating problem seems to start in the high pressure hose, which runs between the Hydroboost and the power steering pump, then travels to the rest of the system.
Has anybody heard of a Hydroboost system heating up before? I have not replaced the Hydroboost yet, and am going to wait until I am more sure that the Hyroboost is the problem.
