hydroboost hoses to steering box
mil_act02
Registered Member
Caldwell,TX
I have a 1984 Fullsize Jimmy with hydroboost brakes.
I am replacing my power steering box(4wd) with a 2wd box for a crossover steering setup. The reman. steering box requires one or more "Tee" connections to tie in the hydroboost lines to the steering box. Can anyone tell me how this is done or post a pic of how the hoses should be routed and where the (Tee's) need to be located. Thanks for any help.
If I am not mistaken, the only "T" you should have is for the return line.
Both 2wd and 4wd only have 1 pressure line and 1 return on the gear boxes.The steering pump may or may not 2 returns which those cose be T togther .
I will post up some pics tonight if someone doen't get them post before that.
He made the exact same post in the Garage.........like I replied to that post, the lines are identical in regards to the box.
