Hydroboost output rod
MetalMulishaMarcus
1 Ton Status
Disneyland
So I took the plunge and bought an Ac delco hydroboost unit and it didnt show up with the much needed parts. Got it off rockauto.
Soo my question, is there any place to get the output rod, plastic retainer, spring and the weird star shaped thing that holds it all in? Or does anyone have an old unit with what I'm looking for that they are willing to part with?
Everything in the picture is what I'm needing.
below is what I used, I was so happy to find it, and it worked out perfect, does not come with the out put rod. call Tallon Hydraulics for the kit, I could not find it on there web site any longer.
Power Piston Return Spring Kit: Tallon Hydraulics P/N: THI-27288 – Tallon Hydraulics $30.00
Another picture of the kit
I will send them an email with a picture to see if they still have it. You said it does not come with the rod, does that mean you didnt need the rod? Or did you still have to use one.
But they also have rods, of many different lengths and sizes, I think you should give them a call instead of emailing.
