Hydroboost parts
gonner
Gray,Ga.
I need the star washer,spring,rod,and plastic washer that goes between the hydroboost and m/c.Also if anyone has a hydroboost brake pedal let me know.If I by chance can't find the original booster parts it shouldn't hurt if I make them from heavy rubber washers and a close to original spring length.What is the diameter of the pushrod.My is eaten up with rust along with other parts.
well I still haven't found the pedal, but I do have a couple of hydroboosts setups that I forgot outside and I don't feel comfortable enough to sel them but I can get you those parts from them.
