Hydroboost pedal return spring?
BILTIT
Lloydminster,SK
Anybody know where to get a replacement spring? I have adjusted the brake switch but it keeps moving, tired of this temporary fix.
The spring is tucked into a little spot way up under the dash in a nasty spot right along side the and to the front of the pedal arm.
You should be able to get a spring at the local hardware stre that will work (with a little tweeking)
The factory setup had a little oval "link" that has a small hole in it for the sping to hook into and the other end of the link goes over the stud on the pedal arm.
Tear into the area so you can see what you need, or stop off at the Bone yard and rip one off a wreck.
Snowy
I dont have the spring on mine, i lost it when i swapped the hydroboost in. We dont have any local wreckers, they decided crushing for steel was more money than selling parts. I may have to call one in the next city and see what they have.
Anybody have a pic and/or dimensions of said spring?
