hydroboost power steering mount
blazinzuk
Buzzbox voodoo
Rexburg Idaho
I need a hydroboost power steering pump mounting bracket.
This is for the power steering pump you use with the hydroboost.
I need it ASAP please PM email whatever
if i recall there the same. i went from steel brackets to aluminum serp belt stuff and the pump bolted up just fine . only thing i had to do was american bolts on the 79 pump. still going fine.
and do you need it for sbc or bbc use ?
Its for a big block, I was reading something about some hydroboost pumps being to thick to use for the normal brackets, but that was on the small blocks.
I could not find anything definite on the big block stuff.
It seems like they should be the same.
Is this what you need ?
I just got this from another member. he gave it to me along with the hydroboost master cylinder. Said to have come form a cucv.
Let me know
Mike
If its from a cucv I am not sure, let me see if I can find out whether the big block mounts are the same as the 6.2 mounts I will let you know
