Hydroboost Swap....which pump did you use?
I did mention it up above but the hydroboost does not like the higher pressures of the KRC pump or the modified stock pump. The peddal will pulsate and make all kinds of bad noises... And yes I would barely touch the wheel and the ram would start moving the tires around, with the current valve it feels very good on the road. Nice and tight.
Wow, that kind of flow would be sweet. But, one of my goals is to keep the number of "specialty" parts to an absolute minimum so that parts can be replaced easily anywhere. I'm going to try it with dual stock units first, but I may give up and join you if that does not cut it...
