PJ Walters
Registered Member
I bought a painless wiring TCC vacuum controlled lockup kit. I also have a slight cam which affects my vacuum. At certain RPMs the tranny stutters between lock and unlock. I feel like the switch is engaging as soon as it hits OD/4th gear and then causes the tranny to shift into 3rd and then back up to 4th and so on. This process continues until I give it some gas to build up my speed and then the lockup engages. I have adjusted the vacuum switch and I still cannot get a proper setting. I am about done with this stuff. I have a few questions before I rip this entire setup out and go to an electronic controlled TCC.
1) The kit calls for a ported vacuum line. I had to run mine into a regular vacuum as the Holley sniper only has one ported vacuum and that goes to the vac advance on the distributer. Can I run two vacuum lines into the ported using a t connector or will that negatively affect my vac advance?
2) Is there a better vacuum switch that folks are using in place of some of the aftermarket junk?
3) If I cannot get this thing to work, what electronic TCC lockup does the CK5 community recommend?
I am at the final stages of this build before I put this thing up for sale. I have a few minor issues with this truck, but I am soooo close to being "done". I do not want to use a manual switch as it just seems to be a pita. Any advice is appreciated.
