ManiacalOffroad
Registered Member
I am currently rebuilding my '85 K5, but right now my urgent problem has to do with my tow rig/daily driver. It's a 1998 GMC Sierra Z71. I live in MI, and have been on disability for 8 years so all of my home/vehicle repairs I have done myself, But I am ashamed to say that ECU's and sensors confound me. So I call upon the experience and knowledge of the mighty CK5 clan.
About 3 weeks ago my rig started missing and sputtering while accelerating through an intersection. It was almost as if it were running out of gas. The fuel pump is relatively new and it is not showing any of the typical sysmptoms of being faulty or soon to be faulty. Later that day I drove it short distance to my son's football practice and it ran great. On the way home I had to feather the gas to keep it moving through first gear, when it shifted the sputtering improved but was still noticable. It also sputters while in park and revving the motor. So I made changes that my wallet (the wife) approved such as:
- New plugs (stock AC Delco) gapped at .60
- New Fuel Filter (AC Delco)
- I put the factory Vortec air cleaner system back on
- New air filter and PCV valve.
- I also used STP throttle body cleaner on the TB.
after I put the factory Vortec air cleaner system back on it was considerably worse so I re-installed the K&N system and it is improved, but still there.
The motor is NOT a stock Vortec 350. It is a .357ci (.40 over) 350 Vortec motor with no other mods.
The trans is a 4L60E modified for flow, cooling and with a shift kit.
I'll list the changes that have been made since I bought the truck in 2000, Please keep in mind that everything Ran FINE for 6 years (since new motor and tranny) Up until 3 weeks ago.
Has no Cat. Converters. The exhaust pipes from where the cats were go from 2 1/4" to 2 1/2" all the way to the Flowmaster 40 series mufflers. Only 3" long tailpipes off of mufflers.
here's where some may cringe, But it has ran fine this way for 6 years. The O2 sensors on the exhaust pipes have been removed. Besides the motor running rich for a few seconds on cold morning startups (and check engine light) I have noticed no difference. Someone told me that with my increased compression that it will aid in performance (meaning helping the motor run correctly) I have no idea if this is true.
I am hoping for some advice as to where to look next Keeping in mind that the truck ran fine with all the above mentioned mods / changes. I never had a problem until 3 weeks ago.
Finally, The last thing I did to the truck before the problem started was I re-charged the K&N filter without incident. I have done this repeatedly through out the years and am confident that I did nothing unusual.
Sorry for such a long post, I just wanted to rely as much info as possible. Please help a fellow wheeler out, I can't finish the motor for my Blazer untill this truck is fixed. TYVM
-Jeff
-Jeff
.. They are old and probably due. I appreciate your time
I'll keep you posted
