THRILLBILLY
I just recently did my 14 bolt swap after months of it collecting dust. Lift blocks wasn't my first choice but with funds tight at the moment and living in an apartment there is only so much I can do. I've never had a problem with running blocks before but this time around I am stumped.
I purchased the block kit through 4WheelParts, I put them in and noticed the block overhanging the backside of the spring perch. DIdn't think anything of it and just kept on going. Finished the install and took it for a test drive. after 2 miles of driving I headed back home, and got out to check everything and noticed something that is really concerning me...
What it looked like before the test drive:
after the test drive:
I pulled everything apart to make sure I didn't overlook anything and test drove it again and the same thing happened!!! I dont understand why it's wanting to kick itself out. The U-Bolts are tight as hell, and all the alignment pins are in place. Before my swap I had a 5 1/2'' block with the 1/2 ton axle that was under there along with the same 6" lift spring and degree shim, and never had an issue. I'm just confused as to why it is doing this...
Anyone have an idea as to why its doing it???
Thanks everyone for the help!
now I can finally move on in the build progress.
