shadowwalker_02
Man this truck has me stumped at this point. I've done some research here and through google and I'm stumped. I still have a "shimmy" in the front end, its not as bad as death wobble but it's noticeable.
Here is what I have done so far,
Alignment
new steering stabilizer
new shocks
drop pitman arm
rotated tires
double checked that everything is tight
no play in the ball joints what so ever
It feels like the right front tire wobbles or like some lug nuts are loose. I have triple checked the lugnuts as well to make sure they are tight.
I have some money so I'm thinking about replacing the bearings and seals on the right front side. I'll rotate the tires again as well.
From what I read when wheel bearings start going out the make a growling type of noise, I don't have any noise coming from the front just a slight wobbling movement. I still want to replace this as its less than ten bucks.
The only thing I can see wrong with it is a slight gap between the locking hub and the housing, I did pull the locking hub off and the grease looks good but I will switch the selectro hubs out for some warns I have.
Have I overlooked something or not looked at something? What could be causing this? Regardless I want to replace the wheel bearing and inner seal for the right side. Does anyone have part numbers for timken bearings and seals for a 8 lug front 10 bolt? Couldn't find em in my search. Appreciate any help idea's or a BFH to beat her with.
Alignment
new shocks
drop pitman arm
rotated tires
10 bucks says its something very simple and I overlooked it.
