I can't find a starter for my '72!
72BlazerTravis
Jefferson City, Missouri
I can\'t find a starter for my \'72!
Apparently my '72 thats a 4 speed manual is using one of those starters like they used on the '55's. The bolts don't go from the bottom side towards the top they go in from each side and sandwich it in. I can special order a starter through NAPA or AC-Delco but they are $80.00!! Where the hell can I find one cheaper cause I'm having to leave it sit. Surely somebody still makes these starters. /forums/images/graemlins/confused.gif Rebuilding it is an option too but this thing is completely shot.
Re: I can\'t find a starter for my \'72!
I didn't realize these were rare. Came stock on my '68 that way. It bolts to the bell housing right? Anyway, picked a new one up from carquest and didn't pay $80. Did you check the cheaper parts store chains?
Also, unless your block is older and not cast for it, can't you just buy a stock '72 compatible starter and bolt it up???????
Nevermind, I found one through O'Reilly's for around $40.00. It had a bunch of cross referenced numbers. The AC-Delco was $80.00, O'Reilly sells its own brand for half that. Too bad I don't even have the money to buy the cheaper one right now. /forums/images/graemlins/mad.gif
So buy the "normal" starter and swap over the nose cone. /forums/images/graemlins/thumb.gif
A later model starter will bolt to the block (if it's drilled) but the hole in the bell housing may not line up. Tried it.
What I was saying was to use the nose part of the old starter, so it WOULD bolt to the bellhousing. And use the new motor (most likly faulty) on that. /forums/images/graemlins/grin.gif
Yeah I'll be putting a new starter on tomorrow, got the one for 40.00 with a lifetime warranty. The only problem now is that the bolt hole that is closest to the flywheel cover is broke so I'll need one of those brackets that attches the front of the starter to the block for support. Should be okay though, with a lifetime replacement I'm not too worried about it. /forums/images/graemlins/cool.gif
Check out this gear-reduction starters. These came off some P-vans that my old workplace wrecked out. They apparently cross over to late '70's Toyota Celica or something /forums/images/graemlins/crazy.gif
Not too sure but I think the one on the top photo on the right side might be a distibutor.
John
Is THAT what it is?!
No wonder it didn't work so good /forums/images/graemlins/rotfl.gif
I just threw a starter that bolted to the block on my engine (the block was already drilled and tapped for that). Works fine. Works even better for the NV4500 conversion since the AA bellhousing won't accept the 4-speed starter.
Tell me more about this bracket that bolts the starter to the block. I have a busted bolt hole as well. I would like to add one too.
It isn't really a bracket...it is cast into the block. Your engine might have the holes tapped for it. Not too many of these trucks have the origional motors in them. Mine has a 400sbc in it so I have to use the offset mount starter.
I have the original engine. I thought it might be like the bracket on my Nova's starter. It had an inline 6 and it had an "L" bracket on the front end of the starter for extra support.
